Civil 3D Forum
freeze alignment but not labels
12 REPLIES 12
Message 1 of 13
bgriffin291
3042 Views, 12 Replies
I am trying to freeze an alignment, but not the labels, in a viewport.
I have labels on a separate layer from the alignment.  This wouldn't be an issue if alignments would generate the linetype correctly like a polyline.
Any suggestions?
Thanks.
12 REPLIES 12
Message 2 of 13
Joe-Bouza
in reply to: bgriffin291
I cannot recreate you issue. I can do it with a touch and freez. Are you certain your labels are on their own layer? I also get line types showing, if xrefed or resident. You can also try setting the style to not show lines and curves.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 3 of 13
sjg
I am able to freeze alignment and leave labels. Check your alignment object layers?
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 4 of 13
bgriffin291
in reply to: Joe-Bouza
Absolutely certain.  Remember this is all being done through a VP in PS, but I get the same result in MS.  Freezing the alignment also freezes the labels.
Alignment is on EX-CL-ALIGN.  Labels are on EX-CL-ALIGN-LBLS.  Label Style and Alignment style is set to layer zero so I can control color and linetype with layer manager.
No xrefs, all resident.
I have no idea what a touch and freeze is.
Autocad C3D 2010
Message 5 of 13
bgriffin291
in reply to: sjg
Aren't the object layer settings just the default for starting a new alignment?
Once I change the labels or alignment to a new layer they don't matter, correct?
Message 6 of 13
Joe-Bouza
post the drawing
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 7 of 13
jmayo-EE
Contrary to the others here I have never been able to do that. 😞 The alg labels will stay on after freezing the alg layer but a regen makes them go away. We use a non plotting pen on the alignment layer for this. You could also just assign an alignment style that does not display the linework.
John Mayo
Message 8 of 13
el_nath
I wouldn't freeze the layer that the alignment is on.  Actually i wouldn't freeze any layer with Civil 3D objects on it, unless I really wanted to remove the object data from memory.  When you do that and regenall the labels will go blank (until the layer is thawed).  What you really want to do is take a look at the alignment style.  The various components of an alignment can be placed on individual layers.
For example, the default "Proposed" alignment style has Lines, Curves and Spiral on C-ROAD-CNTR-N and Extensions on C-ROAD-LINE-EXTN.  These are the layers I would freeze.
The alignment object is on C-ROAD which remains thawed and thus the alignment data is still available for the labels to access.
I hope this helps.
Nathan Selles-Alvarez, EIT
Civil Engineer
AECOM
Nathan Selles-Alvarez, P.E.
Senior Civil Engineer
Message 9 of 13
bgriffin291
in reply to: jmayo-EE
johnm hit the nail on the head and what I suspected would be the solution.
Thanks.
Message 10 of 13
el_nath
Ah, the famous "_No Display" style.  It's a default style for surfaces, but remarkably absent for most other objects.
Message 11 of 13
AllenJessup
I've created a "_No Display" style and an "Almost No Display" style (shows only markers) for alignments. They work fine.
Allen
Allen Jessup
CAD Manager - Designer
Message 12 of 13
Joe-Bouza
Please select "accept solution" so other readers may be aware of your solutionSmiley Wink
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 13 of 13
Hidden_Brain
i have been able to achieve this what you are asking. i found this out accidentally while building our company template. i have the alignment (C-ALIGN) and the alignment label  (C-ALIGN-LBL) object layers set up with "-*" suffix modifiers. this creates new layers for my alignment line and labels when i create an alignment. i can then turn off this new alignment line new layer, but have the new labels layer and the original object layers on/thawed. this lets me have the alignment line off but the labels on. before this, i used to go with a "no plot" method as others suggested. let me know if this makes sense, else i can post some screenshots tomorrow when i am in front of the computer.
Rail Community
