AutoCAD Civil 3D General
Message 1 of 10 (1,981 Views)
Accepted Solution
font problem
1981 Views, 9 Replies
11-29-2011 08:13 AM
maybe you have seen this before and found solution
We are using font Arial narrow for text and for labelling
for some estrange reason the text in paper space is thin and light
(in the way we want it) and the one from the labels (Model Space of course)
much thicker and dark.
Any ideas or solutions you may have applied
Hector
Product Support
AlmasSuljevic
Message 2 of 10 (1,952 Views)
Re: font problem
11-30-2011 06:18 AM in reply to: herb8868
Hi Hector,
Have you checked VP Color, VP Linetype and Lineweight, VP Transparency? These could be found in Layer manager if you scroll over. Look for layer where the label is placed on.
It may be helpful if you could post your drawing and tell what label is behaving that way.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
*Expert Elite*
MarySeufert
Message 3 of 10 (1,935 Views)
Re: font problem
12-01-2011 08:14 AM in reply to: herb8868
I have experienced the same issue. This is specific to true type fonts Arial Narrow included. I've narrowed the problem to the fact that the text object is at an elevation. Do a simple test with a string of text using an arial narrow text style at Z=0, copy the same text string and place it at say Z=100. Print it out and the one at an elevation will be bolder. <See PDF> So this means that any labels using a TTF will be bolder, since the label is at elevation.
I haven't found a work around or fix. :smileysad:
~Mary
_______________________________________________________________________
Normal people believe that if it ain't broke, don't fix it.
Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
Product Support
AlmasSuljevic
Message 4 of 10 (1,933 Views)
Re: font problem
12-01-2011 08:20 AM in reply to: MarySeufert
Good finding Mary :smileyhappy:,
See if this helps as a possible workaround:
Select the text object that is displaying bold and manually change the Z coordinate in the Properties palette to 0 (even though it may already display as 0)
If this happens when using OSNAPS, you can also set AutoCAD to use the current elevation when using OSNAPS, but going to Options > Drafting tab > and checking Replace Z value with current elevation in the Object Snap Options section.
Almas Suljevic
Autodesk, Inc.
*Expert Elite*
MarySeufert
Message 5 of 10 (1,925 Views)
Re: font problem
12-01-2011 09:42 AM in reply to: AlmasSuljevic
This fixes only normal text objects, mleaders, etc. Some Civil3D Labels using the TTF will still be at elevation. No fix for them....
~ Mary
Message 6 of 10 (1,916 Views)
Re: font problem
12-01-2011 10:20 AM in reply to: AlmasSuljevic
Thanks Mary
I did what you had done the other day with the same result and
I tried all the work around suggested with the same result
Thanks again
Hector
Message 7 of 10 (1,903 Views)
Re: font problem
12-02-2011 07:26 AM in reply to: herb8868
I did try all you suggested and still the same
also I tried differets possible solutions like move the text to 0 elevation
and also does not work.
At the end I discovered that making a PDF and printing from the pdf itself it works
and the prints looks acceptable.
Thanks for your assistance
Hector
Message 8 of 10 (1,836 Views)
Re: font problem
04-02-2012 03:40 PM in reply to: herb8868
Is there still not a solution for this problem? This problem always wastes my time and my colleagues time.
Come on Autodesk!
New Member
Message 9 of 10 (1,787 Views)
Re: font problem
05-02-2012 08:44 AM in reply to: herb8868
We have recently upgraded to Windows 7 (64 bit).  The first installation of AutoCAD 2007 was fine.  The font on the screen looked fine, the print outs looked fine, everything was great.  IT moved the items on the server.  Some people didn't need to re-install, however there were some of us who did.  Since this time (at least 6 months ago), I have had thin font on the screen (I hadn't changed any settings), thin font on print outs from AutoCAD, however if I print to PDF, it prints just fine.  If I run AutoCAD in 256 color, looks just fine, however, it modifies the rest of my computer while in AutoCAD and I cannot run my other programs because they aren't 256 color programs.  We have tried re-installing several times, however, we cannot get it to work like the initial insallation.
It is a waste of time to print to PDF, when I should be able to print directly from AutoCAD.
Only thing I can think is that my computer and printer are 64 bit and that PDF doesn't care.  But I don't know where to go from there.
Any ideas?
Member
Message 10 of 10 (1,335 Views)
Re: font problem
02-25-2013 10:22 AM in reply to: herb8868
it is yet another problem that Autodesk just refuses to fix.  What i have happeneing is that any time i use an o-snap to place text or leaders, i get the problem, however if I do not use the object snaps, the text appears fine to me.  If you turn lineweight display on in your drawings you will be able to see the problem without printing.---- and still no fix.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
