Civil 3D Forum
filename at top of screen
5 REPLIES 5
652 Views, 5 Replies
I have a user that has the incorrect filename show up the top of the screen sometimes. Only with more than 1 drawing open of course and not all the time. Anyone ever seen this? civil 3d 2011. Meaning if he has drawing2.dwg open it might still say drawing1.dwg at top. make sense?
5 REPLIES 5
troma
Yes, this has happened to me.  Quite disturbing.
Mark Green
Working on Civil 3D in Canada
normally doint a quick save will fix the display issue.
it's just remembering the previous filename you did a save as from.
Thanks for the input. I figured out how to get it right...jsut didn't know if there was an actual fix. Minimizing the drawing, or exiting autocad will do it also. Problem is, some of these guys don't save very often. Then they do a saveas and.....you get the rest of the problems that can occur when they look up at the filename and decide from that wether or not to save a drawing before closing. Anyway, thanks.
C3D_TomR
I see the issue quite often too using Civil 3D 2012. I can't quite duplicate it, but it seems to happen most often when I qsave a large drawing then use CTRL+Tab to switch between drawings while the drawing is still being saved to the network. It happens so often that I typically check Toolspace to verify which drawing is actually current.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
in reply to: C3D_TomR
My guy here sees it when he is using ctrl tab to switch between drawings as well. That must have something to with it.
Rail Community
