I create a feature line including some arcs. While editing I need to redimension the feature line, but the arcs will lose tangency. Therefore I have to break/trim/delete/manually edit the tangents until they intersect and then FILLET them to get a new arc. I tried EDIT CURVE with 0 Radius but it's not acceptable. Any workaround on this one (filleting feature lines like polylines or a closing option)?
Thank you
Solved by el.Topo. Go to Solution.
Solved by dgordon. Go to Solution.
vk,
by re-dimensioning the feature do you mean changing the size of a radius of one of the curves?
if so the edit curve command for feature lines works. if you want a zero radius there is a delete option to get rid of the curve which will replace the curve with a zero radius fillet. If you have a zero radius fillet and wish to add a curve then the fillet command can be used to do this.
I don't understand when you say that the curve looses tangency. They don't appear to do that at all for me.
thank you!
it's this "Delete" option I could not find that solves my problem.
