Windows 7 64bit running Civil 3D 2013 with service pack 2 installed.
The system runs fine while on the network, but once the user takes it off the network and home or basically off the network it comes up with a FATAL ERROR when the program is started up.
Error is:
Could not load file or assembly MapPublishlmp.dll or one of its dependencies. The network path was not found.
I can ignore the error screen and "work" in C3D fine; just as long as i don't hit the <Continue> button or "X" in upper right hand corner. If either is selected the program bombs out and generates error report.
Have tried to create a shortcut with new profile, but it did NOT work either.
Like i mentioned - systems works find on network but once it is not connected to the network some issue is happening with the dll file for the mappublishlmp.dll
What ever the hell that is...Not doing ANY GIS work with system. NEVER published ANY drawings where this would have come into the mix.
Why?
What?
How?
I am seeing the same error as above with one difference.
I am IT support for the user so have local admin rights to the PC. I can open the program under my user, but I have no idea about graphics so that is as far as I have tested. However the user has the error on trying to open AutoCAD, in this case MAP 3D rather than CIVIL. This is a fresh install on a new PC.
Any thoughts? (I will try granting local admin rights to the user but don't expect that to make a difference as the user has read access.)
Edit: Just had another user report the same error message. I have a suspicion the cause is Win7 as we upgraded the OS at the same time as the software. I suspect the dll file location has changed between WinXP and Win7. I will report back once we have created a new profile from scratch on a new system
