Hi - has anyone ever had this happen?
I created a feature line using the Draw Feature Line command. At some point I noticed that another feature line was underneath it - it's basically the same feature line as the one I drew (same elevations, layout, etc.), but it's on a different layer. If I delete either one of the feature lines (either the one I originally drew, or the one that just appeared), all of the vertices on the remaining feature line disappear, along with all of the elevation data).
This has happened to me several times and I cannot figure out what I am doing to make it happen.
Thanks for any help you can provide.
3dcat =(^..^)=
