Civil 3D Forum
exporting contours from autocad civil 3d to autocad
2 REPLIES 2
THEBOLT
2869 Views, 2 Replies
hey,
i want to export civil 3d contours to autocad but flattening the contours and still defining the elevations of of the contour. is this possible ?
thankyou
2 REPLIES 2
sboon
in reply to: THEBOLT
You can export the contours with elevations, or flattened to zero.  What you export depends on the surface style setting you're using when you run the export command.  You could also export the contour labels if you want to show the elevation of the flattened polylines.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
neilyj666
But please don't pass these on to anyone who needs to recreate the surface...... export the surface as an XML or extract the dtm triangles and WBLOCK them instead.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
