trouble....i'm exporting a surface from 2013 to be used in 2010 for presentation. works great but the contour interval is not the same as the surface i'm exporting. working in 5/25 contours...xml import comes in with 2/10 contours. looked for a setting but can't seem to find. help?
Solved by troma. Go to Solution.
Contour interval is set by surface style. What style are you putting the surface on when you import? You can set that style before or after you import, or you can put the surface on a different style as you import, or later.
Mark Green
Working on Civil 3D in Canada
