Civil 3D Forum
export surface xml and import no boundary (not "full import" problem)
1 REPLY 1
wang890
310 Views, 1 Reply
i have 2 surfaces in the drawing here. see attached.
the datum one export to xml import and export all ok.
the top one will not import with boundary.
any ideas why?
using 2012. not tested in 2014. the surfaces look fine in the drawing.
the xml import/export settings are all good with the "full import" under surface option. i know that one causes no boundary imports if set to point only.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
1 REPLY 1
mathewkol
in reply to: wang890
I can't open the file right now. Are they dynamically linked to a corridor? Try to create surfaace from corridor surface to make one that is not linked, then try. Just a thought.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
