Show only
Search instead for
Entering <0 in the With raw descriptions matching: will kind of work. I think's its a bug and works if you hit OK, if you hit apply and then OK it doesn't work. Also the program doesn't save the value and the next time you return you will need to readd it. There may be a better way.
You can edit the description of all the points with no description in batch to give them a description like ''nothing'' and exclude this description in your group.... It's the way i do..
