Civil 3D Forum
exclude point with no description
4 REPLIES 4
437 Views, 4 Replies
Is there a way to exclude points from a point group that have no
description?
Thank you,
Tyler
C3d2008sp2
4 REPLIES 4
Have you tried "". I have not, just an idea.
Matt Kolberg
Global CADD Systems
www.gcscorp.ca
"PLP" wrote in message
news:5875496@discussion.autodesk.com...
description?
Thank you,
Tyler
C3d2008sp2
Civil3DReminders_com
Entering <0 in the With raw descriptions matching: will kind of work. I think's its a bug and works if you hit OK, if you hit apply and then OK it doesn't work. Also the program doesn't save the value and the next time you return you will need to readd it. There may be a better way.
Christopher
http://civil-3d.blogspot.com/
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Try this:
make a point group and under point groups, select _All Points
under the exclude tab, toggle raw description and type in ?
It works here
Matt Kolberg
Global CADD Systems
www.gcscorp.ca
description?
Thank you,
Tyler
C3d2008sp2
ARicher
You can edit the description of all the points with no description in batch to give them a description like ''nothing'' and exclude this description in your group.... It's the way i do..
Rail Community
