Civil 3D Forum
edit survey figure color
5 REPLIES 5
craigswearingen
1967 Views, 5 Replies
I noticed my figures all had the same color.  I clicked on the figure, went to Figure Properties, then to Figure Properties  again, Edit Current Seclection.  I chose the appropriate color for that figure.  However, it would change EVERY figure in that drawing to that color.  How do I change the color for a particular/specific figure without changing every figure? Thanks.
"There's always room."
Windows 10 Professional
64-Bit Intel Xeon W-2125 @ 4.00GHz
AutoCAD Civil 3D 2018.3
5 REPLIES 5
If you assign a layer in your figure prefix data base and allow the figure style to default to layer 0, color by layer, the figure prefix layer color should win.
Cyndy Davenport
Civil BIM Professional & Enthusiast
Contributing Author to Mastering Civil 3D
Decades of Experience
Thank YOU!!  Tried everything except the "by layer" option.
Jay_B
in reply to: craigswearingen
"How do I change the color for a particular/specific figure without changing every figure?"
Cyndy's recommendation is same as our workflow and how I would go about it but your looking to force the issue without moving the figure to proper layer etc. A different style can be applied to the specific figure but figure lines color must be set to a specific color in the style applied.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
cyndycyndycyndy
in reply to: Jay_B
There is the by style school of thought and the bylayer school of thought.  Neither is wrong. If you are used to setting layers to control display properties, then setting layers in the figure prefix database and using a generic style is the way to go.  If you want to override any display properties of a figure to something other than the layer it's being inserted on by the figure prefix library, then create a special figure style for that.  If you want to adhere to the by style method, set all your figures to be inserted on a generic figure layer and configure a figure style for each figure.  Either method works, but the bylayer method is the easiest most intuitive way to go for new users.
Cyndy Davenport
We were looking to avoid having 1 style per figure so the "by layer" option works well.
Thank you all.
Rail Community
