I want to extend my alignment stationing to begin 5 before the project starts
the stationing should start with -5 and the work begins at 0+00
how do I edit my existing alignment to do this
thanks and I am new at this
Solved by djocwf54. Go to Solution.
Extend your alignment to the point where you want it to start from. (draw a circle 5 radius then select alignment and drag to apparent intersection between alignment and circle is one way)
Select the alignment, right click and choose "Alignment Properties..."
On the "Station Control" tab, in "Reference Point" frame, set the "Station" value to -5.
A warning will come up. Read it. Click ok to make the change, cancel otherwise.
Alignment will now start at station -5.
Alignment properties, Station Control tab is where you edit stationing. Perform the edits to your alignment, click the reference point for 0+00, and make this 0+00, the stationing will take care of itself.
Beware....your proposed profile may shift around as you make edits to the alignment. If you mark the original 0+00 after the edits, then it should be fine.
thanks so much that worked
i tried doing the same thing to the other end and no
matter how much i move that end around it doesnt change in the profile
i fixed the profile from not being edited by
highlight on profile
go to profile view properties
stations
i had it clicked to user specified range
it should have been set on automatic
thanks for all the help
