Civil 3D Forum
dynamic block issue
8 REPLIES 8
Message 1 of 9
509 Views, 8 Replies
dynamic block issue
I made a simple block for a utility pole in plan view. It consisted of a donut with one string of mtext beside it. I had  created it so that the text would orientate itself to be horizontal in each viewport regardless of the ucs angle. I later added a line for a guy wire and made the block dynamic with visibility states. Now I am unable to have the text orientate to a horizontal position in the viewports. Any ideas?
Wil
8 REPLIES 8
Message 2 of 9
tcorey
Edit the block, delete the existing text, add it again.Does that help?
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
Unfortunately that doesn't work.
Wil
Message 4 of 9
Sorry for the late response, but no it doesn't work. Worth a try though. Thanks Wilf Carter Senior Designer [cid:image001.png@01CD640B.1EFDCDA0] 102 Portland Street Dartmouth, Nova Scotia Canada B2Y 1H8 www.ablenvironmental.comPh: 902-466-0050 Ext: 111 Fax: 902-469-4399 wcarter@ablenvironmental.com
Message 5 of 9
Joe-Bouza
Is the text a block attribute or imbedded mtext in the block? Mtext in the block works on my end, but attributes will not
Joe Bouza
Message 6 of 9
mtext Wilf Carter Senior Designer [cid:image001.png@01CD642A.4D091FA0] 102 Portland Street Dartmouth, Nova Scotia Canada B2Y 1H8 www.ablenvironmental.comPh: 902-466-0050 Ext: 111 Fax: 902-469-4399 wcarter@ablenvironmental.com
Message 7 of 9
Joe-Bouza
Gee I put Mtext in a block and it worked. Are you sure you checked the visual fidelity box for the style to orient to the view? Can you post the block?
Joe Bouza
Message 8 of 9
The box is checked. I've tried using text, mtext and attributes. I've tried making the text associative, I tried making it not associative. I tried clicking both "yes" and "no" to "match orientation to layout". When I insert it into a file containing all my other dynamic blocks and go into the block editor, I've tried clicking both "yes" and "no" to "associative. When I try to pick "yes" for "match orientation to layout", it immediately defaults back to "no". I've tried as many combinations of text types and settings as I can think of and nothing works - and I can't stop the "match orientation to layout" to defaulting back to no". Wilf Carter Senior Designer [cid:image001.png@01CD64C4.FDA3A3E0] 102 Portland Street Dartmouth, Nova Scotia Canada B2Y 1H8 www.ablenvironmental.comPh: 902-466-0050 Ext: 111 Fax: 902-469-4399 wcarter@ablenvironmental.com
Message 9 of 9
Volker_C
Can you post the block so that we can examine it?
Thanks!
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
Rail Community
