AutoCAD Civil 3D General
Active Contributor
Message 1 of 6 (378 Views)
.dwt into .dwg
378 Views, 5 Replies
12-14-2012 12:09 PM
I have a township wide contour surface that we received with our LiDAR point clouds.  I would like to add our homemade template to these drawings to make them more useful.  These surfaces are georeferenced in our county coordinate system but the .dwg has ZERO bells and whistles relative to what our template would have to offer.
Can I impliment a dwt into the existing LiDAR surface dwg?
Message 2 of 6 (375 Views)
Re: .dwt into .dwg
12-14-2012 12:22 PM in reply to: jeremy.2012
It's better to do that the other way around. Start a new file with your DWT and insert the LiDAR info into it.
Styles and settings can be transferred from one DWG to another - Manage ribbon tab, way on the right is Styles. This method doesn't get EVERYTHING though.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
AllenJessup
Message 3 of 6 (373 Views)
Re: .dwt into .dwg
12-14-2012 12:24 PM in reply to: jeremy.2012
No. You would have to insert the LiDAR drawing into a new drawing created from your template.
[edited] Yeah. What Matt said!
Message 4 of 6 (365 Views)
Re: .dwt into .dwg
12-14-2012 12:53 PM in reply to: jeremy.2012
You can't insert a .dwt, but you can save it as a .dwg and insert that into the drawing.  It is generally better to start with the .dwt and bring in the data you need, but there are times when I prefer to insert my template into an existing drawing. For example, if there are blocks or layers with the same name in both, and I don't want to override these settings in the drawing with my template settings.
So, if you go this route, you will get all bells and whistles except for any with the same name in the existing drawing.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
Message 5 of 6 (357 Views)
Re: .dwt into .dwg
12-14-2012 01:35 PM in reply to: troma
How do you go about inserting a dwg into another dwg?
tcorey
Message 6 of 6 (355 Views)
Re: .dwt into .dwg
12-14-2012 01:39 PM in reply to: jeremy.2012
Use the Insert command and pick the Browse button.
Another option would be to have the surface file open, then use Civil 3D Styles Manager to import styles and settings from your template.
And yet another option would be to make a data shortcut of the surface and then reference that surface into a drawing created from the template. This lets you keep the surface drawing stripped down, but have all your settings available when you reference the surface.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
