AutoCAD Civil 3D General
Member
Miguel7799
Message 1 of 4 (224 Views)
dwg topography to 3d solid
224 Views, 3 Replies
11-13-2012 04:04 AM
Hi. I need to create a 3d terrain solid from dwg nivel curves (contours). I tried with loft command but the lines are too detailed and my pc takes a eternity to loft just 2 lines and i have a lot of it.
I was wondering if use revit will be a good option. Can you please tell me the best way to do it and dont create a extensive 3d file?
Regards
antoniovinci
Message 2 of 4 (215 Views)
Start from here, sir.
11-13-2012 05:28 AM in reply to: Miguel7799
*Pro
dgordon
Message 3 of 4 (154 Views)
Re: Start from here, sir.
11-29-2012 10:39 AM in reply to: antoniovinci
before he can use that advice he has to first create a C3D surface from the contours.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
tcorey
Message 4 of 4 (150 Views)
Re: dwg topography to 3d solid
11-29-2012 10:48 AM in reply to: Miguel7799
Are you using Civil 3D? If so, do as the previous poster suggested and create a Civil 3D surface from your contours and then follow AntonioVinci's link.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
