Civil 3D Forum
drawing lines using nodes
5 REPLIES 5
mikerobe100
1242 Views, 5 Replies
If I draw lines between nodes and then list the lines it gives me slope distances. how can I set it to draw 2D lines but still have 3D nodes? I want my points to display the correct elevation but when I draw lines connecting them I want the line to be 2D so when I list them I get the correct bearing and a horizontal distance.
5 REPLIES 5
Jeff_M
in reply to: mikerobe100
Set OSNAPZ = 1. This will allow you to snap to the nodes and ignore the Z value. Note that this setting is not saved and defaults to 0.
Jeff_M, also a frequent Swamper
troma
Another option: use polylines instead.  They will never draw in 3D.
Mark Green
Working on Civil 3D in Canada
Jeff_M
in reply to: troma
However, they WILL draw at the elevation of the first point.
antoniovinci
..or draw a 3Dpoly snapping on the nodes, then in a plan view _FLATTEN it.
if they are nodes controled by a point style you can set the point style to flatten to elevation 0 and then use any line command with osnap for node.
Rail Community
