hi
I have a program autocad civil 3D 32 bit I want to be downloaded to the system 64 bit , What is the method for this Installation
Regards
Hi 218812,
You will need to download the 64-version of this program if you want to be able to install on your 64-bit system. You can download it from Matt, our Virtual Agent. Click here and select the option Downloading and Installation -> Software Download Links -> I Need to Redownload my Product; then simply choose the program and version that you wish to download.
Best regards,
Did you download the install from your subscription center or do you have the physical install media (USB or DVD)?
If the former, you probably need to download the correct version, I don't think the download includes both. If you have the physical install media, it should include both versions.
hi camilo
thank you i have only 32-version , my net speed is very low i need more than 24 houre to download it
Hi 218812,
It is not possible to install a 32-bit product on a 64-bit system and have it work flawlessly.
If you are a Subscription Customer, you can request physical media to be sent to you. What version are we talking about? 2014?
Best regards,
Hello @kehindefagboyo14
Here is the link to download AutoCAD Civil 3D. Are you a Subscription Customer?
Best Regards,
Wendell
Call your reseller, and see if he/she still has a copy, and/or contact Autodesk directly. As a general rule, only the current version and 3 versions back are available.
