In addition make sure the layers to display the data aren't turned off.
Also John - wopuld you mind turning your Capslock key off when posting to
the Newsgroup. Is is so hard to read compared with normal sentence case
text.
Laurie Comerford
CADApps
www.cadapps.com.au
"Himanshu Gohel" wrote in message
news:4946825@discussion.autodesk.com...
JohnPowell wrote:
> I AM NEW TO CIV 3D 2006. I HAVE BUILT A PROFILE AND ALL THE PRE-REQUISITE
> STUFF TO GET TO IT. I FINISHED THE PROJECT AND DRAWINGS (A COUPLE DAYS
> WORK) AND WENT INTO THE DRAWING THIS MORNING TO PLOT AND THE PROFILES ARE
> GONE. I DID A DRAWING RECOVERY (AS PROMPTED) AND THE GRIDS ARE STILL THERE
> AND WHEN I HAVE THE MOUSE OVER THE GRID IT GIVES STATIONING AND ELEV. HOW
> DO I GET THE PROFILE OF MY SURFACE BACK?
John,
Looks like you might have more than one issue here:
Did the profiles 'disappear' before or after you were asked to recover
the drawing?
In your drawing, turn on the toolspace window (SHOWTS), and drill down
into your site till you find the profiles in question. Select each one
and right-click to bring up its properties. Does the data look correct
(min-max station/elevation) in the Profile Data tab? That would ensure
that your data is present.
Next go to the Information tab, and look at the Object Style. select
the drop-down button next to edit and choose "Edit Current Selection".
In the Profile Style dialog, switch to the Display tab. Check that the
visibility flags for Line/Curve/parabola/.. are turned on and that the
colors don't match the background.
If all this is OK and you still don't see the profile, please zip your
file and post it to the newsgroup. Thanks.
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information: http://www.autodesk.com/civil3d
