Civil 3D Forum
dimension units
5 REPLIES 5
madmaxdesign
448 Views, 5 Replies
dimension units
hello i am new to here so probably for you guys this is an ubersimple issue to solve
i have my software that is set in inches and decimals (meaning 1 1/2" is shown as 1.5000)
i obviously need it to show as 1 1/2
i tried the UN command but despite the panel showing it the proper way, the drawing dimensions won't change...
please help!
5 REPLIES 5
BrookeCSU
in reply to: madmaxdesign
Have you tried typing "-un" at the command line? You will want to set the value to either 4 for Architectural or 5 for Fractional.
madmaxdesign
in reply to: BrookeCSU
now i tried and while it changes it for the "build" dimension (the numbers showing while i build something) it doesn't change it in the annotation
Pointdump
MMD,
You probably need to modify your Dimension Style.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Joe-Bouza
If you are using civil3d to design I would suggest not using arch units.
If you must draw primatives in this units, I suggest using vanillad acad and xrefing into the c3d design drawing at a scale of 1/12
Your Name
Your Name
madmaxdesign
in reply to: Pointdump
DAVE THANKS A BUNCH!
MADE IT!!!
Rail Community
