hello i am new to here so probably for you guys this is an ubersimple issue to solve
i have my software that is set in inches and decimals (meaning 1 1/2" is shown as 1.5000)
i obviously need it to show as 1 1/2
i tried the UN command but despite the panel showing it the proper way, the drawing dimensions won't change...
please help!
Solved by Pointdump. Go to Solution.
Have you tried typing "-un" at the command line? You will want to set the value to either 4 for Architectural or 5 for Fractional.
now i tried and while it changes it for the "build" dimension (the numbers showing while i build something) it doesn't change it in the annotation
MMD,
You probably need to modify your Dimension Style.
Dave
Dave Stoll
Las Vegas, Nevada
If you are using civil3d to design I would suggest not using arch units.
If you must draw primatives in this units, I suggest using vanillad acad and xrefing into the c3d design drawing at a scale of 1/12
Your Name
