any way to change the horizontal scale independent of the vertical scale, the verticle exaggeration cant do it if i am not mistaken
from the help menu:
Vertical Exaggeration
Specifies by how much the elevation values are increased in the profile view for greater visibility. Enter either 1 for no increase in scale or a larger number to increase the scale. The elevation values are multiplied by this value, so a larger number increases the amount of exaggeration in the profile view.
The drawing’s horizontal scale factor (H) is divided by the vertical exaggeration setting (X) to obtain the profile view’s vertical scale (V).
For example, if your drawing’s horizontal scale is set to 1”=50’, and you want the profile view’s vertical scale to be 1”=10’, then set the vertical exaggeration to 5.
