Civil 3D Forum
dbconnect possibilities ?
13 REPLIES 13
Message 1 of 14
cyberflow
602 Views, 13 Replies
Hi there,
It's been several times i came across the command or icon DbConnect.
I've spent a bit of time googling about the subject and just results of people who arent able to connect instead of seeing it at work.
What are the possibilities of using a database and connecting it to the drawing ?
Using : Autodesk Civil 3D 2022& 2023
AKA Frank Freitas, Senior Roadway Designer @ Kiewit
13 REPLIES 13
Message 2 of 14
Murph_Map
in reply to: cyberflow
@cyberflow wrote:
Hi there,
Forget about DBConnect, that's a vanilla Autocad tool. If you are using Civ3D you have all the Map3D funtions to connect to databases using data connect (FDO) and Mapattachdb. search for those terms and you should find more info on them.
Murph
Supporting the troops daily.
Message 3 of 14
cyberflow
Hi there Murph,
First of all, thanx for replying.
I'm not famillior with the term "vanilla" in Autocad ?
What does it mean ?
I will search a bit more on Mapattachdb command.
But that's for working with survey's and data like that or there can be other applications ?
Message 4 of 14
Murph_Map
"Vanilla" is the term for plain Autocad, no favors among Autocad geeks/junkies/nerds.
There are other applications for Mapattachdb besides survey data. What type off database and data are you wanting to connect to?
Murph
Message 5 of 14
cyberflow
in reply to: Murph_Map
Well i was asking myself if it was possible to store data and then make them show up in fields or things like that ?
I just wanna know what are the possibilities of link a database with civil 3d
Message 6 of 14
Murph_Map
If you did a default install,look at the dwg in this folder C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Database Connectivity .
Murph
Message 7 of 14
cyberflow
Hey hi Murph !
I did check out the DWG sample.
But i don't see what it can do....
(I really feel like a total noob right now)
Message 8 of 14
Murph_Map
Use the dbconnect command and select to view the tables/queries. You may need to connect to the DB (in the same folder) and use MS Jet drivers.
Murph
Message 9 of 14
cyberflow
Hey hi Murph !
I opened Autocad Vanilla to use the Dbconnect command. (I just learned that ...)
Now i think that nothing happens because i cant connect to the db ?
Do i need to install some sort of server to use the database ?
Message 10 of 14
antoniovinci
Sounds like those 64-bit Jet drivers aren't working properly, sir.
What about renting your AD dealer for 1-2 hours, just to let him configuring all..?
If your dealer went yesterday bankrupt, well, try to join your vector shape to the external database, thru the opensource Qgis.
Once you have the new "clever" shape, you load and label it in Civil.
Message 11 of 14
Murph_Map
Do you have MS Office (Access)  installed on your workstation?
Murph
Message 12 of 14
cyberflow
Yes i do on my workstation.
Message 13 of 14
Murph_Map
Try going into the ODBC Administrator for 32 bit and set up an odbc connection.You may also need the 64 bit drivers from Microsoft.
Murph
Message 14 of 14
cyberflow
in reply to: antoniovinci
HI there,
Was thiking about buying this book :
http://www.amazon.ca/dp/0766816400/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=20Q61WN366DIJ&colii...
I don't know what to think about it
Afterall it's 15 years old version of Autocad.
Any tought on thisbook ?
Or maybe a good book who talks about database ?
Rail Community
