3dcat
Message 1 of 7 (170 Views)
data shortcut surface not inserted at correct location
170 Views, 6 Replies
01-24-2014 06:31 PM
I had a drawing (Drawing #1) that I created a copy of (I'll call the copy Drawing #2).  In Drawing #2 I created a finished grade surface ("FG") which consists of feature lines drawn within the property lines of the site.
I then created a data shortcut of the FG surface and promoted it into Drawing #1.  The surface is offset and rotated from the site - I would expect it to line up exactly within the property lines.
I have done other surfaces this way and haven't had this problem.  Any ideas why this is happening?
Thanks!
wfberry
Message 2 of 7 (143 Views)
Re: data shortcut surface not inserted at correct location
01-25-2014 06:22 AM in reply to: 3dcat
Make sure your UCS is set to World.
Bill
3dcat
Message 3 of 7 (136 Views)
01-25-2014 01:40 PM in reply to: 3dcat
Hi Bill,
Thanks for your reply. I checked and the UCS coordinates are set to world.
I have some more information on what is happening...
The coordinates of SW property line corner are 8715.89, 9376.34 in both Drawing #1 and Drawing #2. When I promote the data shortcut surface into Drawing #1, the surface SW property line corner is located at -9376.34, 8715.89 (the X = - original Y and the Y = original X).
I am able to work around the problem by moving the surface and rotating it, but it would be nice to have it come in at the correct location.
Thanks again for your help.
wfberry
Message 4 of 7 (120 Views)
01-26-2014 04:41 AM in reply to: 3dcat
Perhaps one of the files has the Base command set different.  Base should = 0 (zero) in both drawings.
OR you could have US Survey Foot and International Foot (Your large difference in location makes it seem unlikely.)
Just guessing here.
Bill
3dcat
Message 5 of 7 (111 Views)
01-26-2014 03:12 PM in reply to: wfberry
Hi Bill,
I checked the base and it is zero in both drawings.
Thanks for your suggestions...  this is really a strange problem. :smileyfrustrated:
Valued Mentor
ericcollins6932
Message 6 of 7 (97 Views)
01-27-2014 06:45 AM in reply to: 3dcat
The north definition is messed up if coordinates come in 90° apart. But for the life of me, I don't know what would cause that behaviour.
Eric Collins, P.Tech.(Eng.)
Win 7 Enterprise SP1 64 bit
Intel i7 3770 @ 3.40 GHz
16 GB RAM
Civil 3D 2012 SP2
Valued Contributor
sturner7277
Message 7 of 7 (93 Views)
01-27-2014 06:54 AM in reply to: ericcollins6932
did the drawing get rotated, instead of the dview?
-Sean
Just a CAD Manager for a Civil Engineering firm...
Win 7 pro 12gb
NVIDIA Quadro 2000
LDD 2009
IDS 2014
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
