Civil 3D Forum
creating solid from surfaces?
1 REPLY 1
3851 Views, 1 Reply
TO all
I currently have a problem and am not sure how to address it.
I have an undulating surface made up of 3dfaces.  I also have another surface below that surface and I want to make a solid between the 2 surfaces.  I can convert the faces to mesh or surface.  Is there a way in AutoCAD or any of the AutoCAD verticals to create a solid between these two undulating surfaces?
AHGA
Shawn
1 REPLY 1
AlmasSuljevic
Hi Shawn,
I know that AutoCAD can create a carved surface out of a solid. Since you can create solids, you may try these links to see if it helps.
Good luck!
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Rail Community
