hello everybody
I create a corridor using a trench assembly and targets to the existing surface but the corridor did not stop to the surface its like the picture down i use corridor boundaries automaticlly trench_daylight .
any suggestion
thanks
It looks as if the boundary is not being applied. Create a dummy baseline and then you'll have access to the Corridor Extens as boundary option. Also, you can use the Create Boundary from corridor command to create a polyline which you can use as a boundary.
thank you for replay
i don't know why trench daylight boundary not work ? and how can i Create a polyline Boundary from corridor command ?
thanks
When you have trouble finding a command you can search using the application menu. Just type in boundary and corridor and you'll see it.
If an automatic daylight boundary is not working it's usually one of two reasons. Either the boundary featureline crosses itself at the inside of a curve (we call that a bowtie), or your corridor has sections where it was unable to daylight properly.
When you rebuild the corridor are there any error messages in the Panorama dialog?
when i rebuild the corridor there's a lot of errors messages told me the intersection with target could not be computed left intersection.
i dont know why i get these messages ?
thanks
