I want a dynamic FL from corridor A to be used as a target in corridor B. That shouldn't cause a problem, right? Beacause I just did it and c3d got caught in some continuous loop rebuilding the corridor.
Joe Bouza
Solved by Joe-Bouza. Go to Solution.
Joe Bouza
What I was trying to convey is you can create a target alignment for the intersection that is dynamic to the ETW alignment by creating an Offset alignment at zero units FROM the ETW alignment. Thus any changes to the ETW alignment will be propogated to the intersection.
The reason for making the offset alignment is to allow you to limit the length of the target along the ETW.
Joe Bouza
