How can I copy a profile view style from one drawing to another? I can't seem to locate the ones I created in toolspace to be able to drag them from one drawing to another.
Solved by Jay_B. Go to Solution.
Open both of the drawings and set the drawing you want to copy the profile view style into as current drawing window.
On Settings Tab of Toolspace click the dropdown that says "Active drawing settings view">change it to "Master view"
Expand the drawing name that contains the desired profile view style on Settings Tab of Toolspace>Profile View>
Profile View Styles>Style to be copied>
Left click on the style to be copied and slowly drag it onto the drawing space of the drawing the style is being copied into.
WOW!!!! Thanks so much....I did not have the dropdown set to "Master View"...I had it set to "Labels only view", which explains why I could not see the Profile View I had created.
