AutoCAD Civil 3D General
New Member
wbcad21
Message 1 of 12 (341 Views)
converting an alignment to a shapefile in C3d 2011
341 Views, 11 Replies
02-04-2013 02:09 PM
Can someone suggest a method for exporting an alignment as a shapefile in C3D 2011?  Any help would be greatly appeciated.
tcorey
Message 2 of 12 (322 Views)
Re: converting an alignment to a shapefile in C3d 2011
02-04-2013 04:28 PM in reply to: wbcad21
You can explode it down to a polyline object and then use Mapexport to export the polyline. The type of export will be Line.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
sboon
Message 3 of 12 (309 Views)
02-04-2013 06:35 PM in reply to: tcorey
Don't explode it - offset 1m right then 1m left to create a polyline copy of the alignment.
tcorey
Message 4 of 12 (298 Views)
02-04-2013 10:33 PM in reply to: wbcad21
I agree. That's better than exploding.
Tim Corey, Owner
Redding, CA
Murph
Message 5 of 12 (293 Views)
02-05-2013 04:24 AM in reply to: sboon
Just remember to delete that polyline afterward or you may forget it's there and months from now want to know why your alingment turned into a pline or has a pline on top of it. Now if you want some data in that shp file you can export to SDF then convert that to shp format by importing it into a blank dwg and create Object Data then export to shp format.
Murph
Supportting the troops daily.
TRogers
Message 6 of 12 (285 Views)
02-05-2013 05:37 AM in reply to: Murph
You can alternatively export civil objects out to an .sdf file as well.  Works better in my opinion...
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
tcorey
Message 7 of 12 (270 Views)
02-05-2013 08:23 AM in reply to: TRogers
Todd, I like this option because it's cleaner than screwing with your drawing by exploding or offsetting.
Once you have the SDF file, don't you then have to import that into a new drawing from where you would use Mapexport to create the SHP?
I notice that when you bring the object back from SDF, it has some object data available. Do you know a way to tell the SDF export which data to include?
Tim
Tim Corey, Owner
Redding, CA
TRogers
Message 8 of 12 (269 Views)
02-05-2013 08:26 AM in reply to: tcorey
Unfortunately there is not way to select objects to export.  I have this on the wish list though!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Murph
Message 9 of 12 (255 Views)
02-05-2013 02:59 PM in reply to: TRogers
Didn't I say that. :smileyhappy:
Murph
TRogers
Message 10 of 12 (251 Views)
02-05-2013 03:02 PM in reply to: Murph
Haha Murph.  I hope we were posting at the same time.  However, both of our posts are EARLY in the morning (pre-coffee)!!
*Civil 3DJ*
Todd Rogers
Visit my blog here.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
