Civil 3D Forum
convert pipe networks to polylines
5 REPLIES 5
lisa.stearns
6213 Views, 5 Replies
I have a drawing that started as a pipeline network and am trying to easily convert the pipes to polylines or something of the sort to export to shapefiles. any suggestions?
5 REPLIES 5
mathewkol
in reply to: lisa.stearns
If all you need is a shape file, you can export to SDF then use the Map 3D feature Bulk Copy to make a SHP file. There is not tool that I know of to convert pipes to polylines.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Jay_B
Would Landxml export of the Civil 3d network work to then Importlandxml into another software etc.?
http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-A7D39DAE-5A6C-4A3C-A842-023E727...
Structures and pipes can be reduced to AutoCad primitives by the "Export to AutoCad" command which exlodes everything and all inteligence is lost.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
A bit of a round-about way - export the pipe network to Autodesk AutoCAD Storm and Sanitary Analysis (SSA) and export to SHP from there.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
mathewkol
in reply to: Matt.Anderson
Nice.
Please note we have moved. Our new address is:
4040 Graveley Street
Burnaby, BC
V5C 3T6
Matt Kolberg, Applications Specialist
c: 604.803-5963
Improving field to finish productivity
cansel.ca [Description: Description: Description: http://www.googleplus-vs-facebook.com/facebook.png] <> [Description: Description: Description: http://t0.gstatic.com/images?q=tbn:ANd9GcQkxJl0nu584FrSblIknohzw0tAMtmGSSs9hAnxRS6kFOpzPYmvXQ] <>
[autodesk customer satisfaction program new]<>
Matt Kolberg
mspicerXYQGX
Just explode it all twice. Once to turn it into a block and once more to turn them into polylines.
Rail Community
