Civil 3D Forum
compute angles relative to true north
17 REPLIES 17
Message 1 of 18
darreng_oa
3073 Views, 17 Replies
line property angles seemed to be displayed in bearings.  is there a way to change this to display relative to true north?
thanks, oa
17 REPLIES 17
Message 2 of 18
HansSMS
in reply to: darreng_oa
Type UNITS, bottom of Dialog hit Direction Button, Direction control dialog select North 270d0' This sets your North refernce to AutoCAD's 270°.
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
Message 3 of 18
Pointdump
Darren,
This might be a place to check:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 4 of 18
odoshi
If you want azimuths, you can look in the command settings for Parcels or maybe make a custom Label style.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
Message 5 of 18
ericcollins6932
in reply to: Pointdump
Similar to this, you can also fix your labels to show north azimuth. Pretty sure they are in bearings by default.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 6 of 18
darreng_oa
no luck. still cannot figure out what the angle number is in properties. my goal is for it to display the direction the line was drawn, with north = 360, east = 90, south = 180, and west = 270. currently, i have to determine the quadrant the line is in, and then adjust accordingly.
thanks!
Message 7 of 18
Pointdump
Darren,
Please clarify what you want to do. Are you trying to label a line with Azimuth? How about a screen grab showing us what you'd like things to look like.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 18
darreng_oa
hi dave - thanks for the quick reply
i have a series of lines on a map in civil 3d, and i in need to follow those lines in the fieled using a magnetic compass. so therefore, i need the heading for each line.
thanks!
Message 9 of 18
Pointdump
OK, Darren, then it looks like the easiest will be to convert them by hand. Amazingly, I can't find a way to simply label a line with an Azimuth. I thought that would be the easiest way, and I'm sure it can be done, but I wasn't able to find a way.
Any data collector usually has a quick-n-easy function to convert between bearings and azimuths, and there's probably a conversion App for your Smartphone. Civil 3D has a really cool Quick Calc that should be able to do those conversions quickly and easily, but I can't figured out how to use it.
Sorry I'm not much help.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 18
AllenJessup
I would have thought that creating a Label Style was all that would be needed.
However that doesn't work when I try it. From 0° to 180° it labels the line at 90° 00' 00". From 180° to 360° it's labeled 270° 00' 00".
Allen
Allen Jessup
CAD Manager - Designer
Message 11 of 18
AllenJessup
The math is fairly easy. In the NE quadrant you've already got the angle. In the SE quadrant subtract the angle in the Bearing from 180°. In SW add the angle to 180° and in NW subtract the angle from 360° I had to do that all the time when leading a Survey party. It helps to have a calculator that converts decimal angles to DMS.
Quick Calc Quadrant is a Quadrant Snap to a circle.
Allen
Allen Jessup
Message 12 of 18
AllenJessup
in reply to: AllenJessup
I found out that the Label Style does work. My drawing had some serious damage. That's why I got those results.
Allen
Allen Jessup
Message 13 of 18
Pointdump
Allen,
I'm not sure how Quick Calc Quadrant works, but that would sorta explain the preposterous numbers I got.
After your success with Azimuth labelling, I steeled my resolve and figured out how to label a line with an Azimuth:
So Darren, to answer your original question, I don't know how to get Properties to show an Azimuth, but a Line Label is definitely do-able.
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 18
AllenJessup
Good work Dave. Whatch those old references. The Quick Calculator is just a GUI for the geometry calculator. See attached.
allen
Allen Jessup
Message 15 of 18
Pointdump
Allen,
Thanks for the Geometry Calculator Manual. Did you write it? It's brilliant!
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 18
HansSMS
The original question was how to get the azimuth to show up in the line roperties under the angle item. My solution works, provided you have North straight up the drawing. If not, set a UCS to the Y-axis is in line with your North, and the angle item in the line properties box will show correctly.
Hans Moller
Gladstone Australia
Message 17 of 18
AllenJessup
No Dave. I compiled it from various AutoCAD help files and added a little explanation here and there. This was a long time ago when Help files were truly helpful. I don't think I could do the same thing today.
Allen
Allen Jessup
Message 18 of 18
AllenJessup
in reply to: HansSMS
Yes. That will work. However I stay away from the Units dialog. I use the recommended AECDWGSETUP. I'd be worried what changing the orientation would do to Civil if someone forgot to set it back to 0. I don't let anyone here use UCS for the same reason.
Allen
Allen Jessup
Rail Community
