Holo!
new on theese groups..
now, globaly, the object i modeled is simple. it's a simple plateau with a 1% inclination that cuts/fills where needed at a slope. that was easy. the tricky bit i'm trying to make out is this - on one side, there's a HUGE fill that will have to be constructed with the use of geotextile trought compressed layers. is there ANY reasonable way of modeling those layer, maybe displaying them in samples and calculating the amount of geotex used?
the drawing with the surface, profiles and the geotex layers (in it's thickest part) is in the attachment. ANY sugegstions, no matter how complex/simple are more than welcome and thanked for in advance 🙂
Solved by sboon. Go to Solution.
That was seven months ago. I don't keep example files that long, but you should be able to recreate the assembly from the instructions.
