Civil 3D Forum
cogo points plan readability
13 REPLIES 13
Message 1 of 14
tingraham
877 Views, 13 Replies
My delima is regarding cogo point readability. I'm used to LDD so this may be the issue. I set a cogo point but I want it to stay in the same orientation. if I use orbit or dview the cogo point data reorients (rotates) to line up horizontally. I would like the data to remain as set originally. I tried changing plan readabilty in label styles but when I drag the point it rotates to the current view orientation. Is there a way to control the rotation once dragged so it does not reorient if I change the orbit or dview?
13 REPLIES 13
Message 2 of 14
john.mckenzie
in reply to: tingraham
I believe you can in the dragged state settings. I will check.
Message 3 of 14
Not sure if this works and am not at a point to test it.
try changing dispaly to "as composed" and see if it helps here.
Let us know if it worked so I dont mislead the next reader
Message 4 of 14
tingraham
in reply to: john.mckenzie
John,
Much thanks. It works to control the cogo point text. But, now I see that the leader needs to be controlled. Any idea.
Message 5 of 14
john.mckenzie
show me a picture of what you are getting.
Message 6 of 14
john.mckenzie
I would go to label styles and select
right click and edit the leader opions shown here
leader attachment and leader justification.
I am just guessing again but HEY I'm on a roll so why not.
Remember to accept solutions and a KUDDO once in a while is great for the on-line ego LOL
yeah, I have NO pride.
Message 7 of 14
tingraham
See attached before and after orbit snap shots.
Message 8 of 14
tingraham
If the display is set to composed then everything else is greyed out. If display is staked then I can change leasder attachment. which did not resolve the odd leader once dragged. Appreciate your help. Any other idea.
Message 9 of 14
john.mckenzie
yup.
change back to stacked. this will allow you tio change the options for the leader.
Change back to as composed afterwards and see what happens.
Still guessing.
Message 10 of 14
I suspect the one you want to change is leader justification.
Still guessing here.
Message 11 of 14
tingraham
I've tried changing leader justification to false with no difference. Also being silly I tried all the attachment options. No change????
Message 12 of 14
john.mckenzie
I am all out of ideas in this old head. Sorry. Got you half way there.
Message 13 of 14
tingraham
John, Thank you for your help.
Tony
Message 14 of 14
john.mckenzie
Here is another take on the issue that may actually solve your problem. We may have only put a band-aid on it with my suggestions.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Community/Point-label-dragged-state-settings-Flipped-...
Rail Community
