Dell Precision PWS390
Intel(r) Core(TM)2CPU
6600 @ 2.40GHz
2.39 GHz, 3.25 GB of Ram
Nvidia GeForce 8400 GS 1024mb DDR3(new)
Opening drawing uses up memory (1.2g) vitural memory (1.4g) then crashes and asks to send a report. Earlier characteristics were if the drawing opened the memory would be near max limits, then I would minmize the drawing and the memory would go down to about 20k. Restore the drawing and it would slowly start building its way back up again.
The old video card had the same results but the newer card loads faster. Old card had 256meg.
5 xrefs, all civil3d. All -purged. Ran regaps. Took out all misc drawing scales. No xrefs in the xrefs.
I have attach a screenshot of the task manager before it dies.
It has been a while since I have been here so if I dont respond please email me. ldodge@rogina.com
What version of Civil 3D? It would have to be pretty old to have any hope of using it effectively with 4GB of RAM.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T3610, Xeon CPU 3.70 GHz
Win 7 Pro, 64-bit,32 GB RAM, Nvidia Quadro K4000
Samsung SSD 512GB
HGST (WD) 512GB drive
Allen Jessup
CAD Manager - Designer
Mark Green
Working on Civil 3D in Canada
@troma wrote:
Allen, I'm running C3D 2011 & 2013 on Win7 32bit. I believe I have the 3GB switch enabled, so of 4GB onboard, there is 3 for C3D to play with. Not saying I wouldn't like more, but it gets the job done.
Well..... I suppose it depends on what you're doing and maybe how well you do it. But I got very familiar with the out of memory problems the OP described. I also spent a lot of time getting coffee while waiting for things to process. Not so much the past couple of days since I got my new computer.
Allen
Allen Jessup
You might want to point out to your boss that you're getting paid by the hour to drive an oxcart, while the rest of us are using automobiles - relatively speaking.
Amazon sells them for $200, Win XP "Pro". Overstock is selling them to the clueless at $240.
Search the Dell model number, it's not rocket science 🙂
XP ain't Win 7.
The OP is getting paid to sit on his hands: obviously his firm has a lot of money to waste paying professionals to wait around for software to do it's thing.
@Anonymous wrote:
Its kind of like the first car you get. You dont have much input on what it is, but its yours.
If that's what you have to work with. You'll have to accept it's limitations. There will be some drawings too large to open. You might try opening it as Autocad only and Wblock out all the non-Civil 3D entities. Then break those out into smaller drawing and Xref them in and out as needed. Also use Drefs extensively.
If you have 12 tons to move and only have a 1 ton truck. You'll have to make a lot of trips.
Allen
Allen Jessup
