Civil 3D Forum
civil 3d 2009 64bit?
3 REPLIES 3
TherealJD
2116 Views, 3 Replies
I thought that a 64bit version of civil 3d only started in 2011. However, at my work they have an image labelled as civil 3d 2009 64. So is there a 64bit version of civil 3d 2009? And is there a way to determine if you're running a 64bit vs 32bit? Nothing is indicated in the "about" box...
3 REPLIES 3
DarrenP
in reply to: TherealJD
there is no such thing as civil 3d 2009 64 bit 2011 is the first native 64 bit civil 3d
anything below 2011 is 32 bit
DarrenP
SethHall
I believe in 2009 you could create 64-bit deployments of the 32-bit application to deploy to 64-bit machines. However it still remained a 32-bit application up until Civil 3D 2011 was released. I am guessing this is most likely what you are seeing.
Hope this helps!
Seth Hall
Product Owner
Model Builder
TherealJD
i did some checking and it llooks like that is the case. the x64 is a deployment image. Thanks for confirming.
Rail Community
