Civil 3D Forum
civil 2010 and 2011 volumes of a stockpile by elevation
8 REPLIES 8
Message 1 of 9
1066 Views, 8 Replies
I have a few vary large stockpile that i need to het volumes of the stockpile at 1 meter intervals- is there a quick way of doing this, other then finding the area of each elevation and calulating the volumes.
RH
8 REPLIES 8
Message 2 of 9
tcorey
Create an OG and FG surface. Create a volume surface that compares the two.
Use Bounded Volume (on the Analyze tab of Ribbon) and specify each incremental elevation as a datum. You will get a volume for each elevation.
You must press D (enter) before each datum input. So if you want 120, 121, 122, you have to press D <enter> 120 <enter> D <enter> 121 <enter>, etc.
The printout goes to the AutoCAD text screen, so you can easily Copy and Paste to your work processor or the Mtext for placement on the drawing.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
Thank you- but I am having problems with setting the datum. I am not getting a prompt for the elevation, is there a setting i should be looking at?
Message 4 of 9
tcorey
Are you typing D for datum? After doing that you should be prompted for the datum elevation. That's the elevation at which the volumes are calculated.
Tim Corey
Redding, CA
Message 5 of 9
I am working it from the start again to see if I am missing anything
Message 6 of 9
mathewkol
Tim, is that feature available in 2010 and 2011? I can't remember.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 9
Joe-Bouza
Sounds like an inverted pond? Would stage storage help?
Joe Bouza
Message 8 of 9
tcorey
in reply to: mathewkol
This feature is definitely in 2011 and 2012. I am not sure about 2010.
Tim Corey
Redding, CA
Message 9 of 9
BrianHailey
in reply to: tcorey
I blogged about this subject using 2012 and the volumes dashboard extension. You can use a similar method without the dashboard extension, it's just a bit more manual.
http://civil3dplus.wordpress.com/2012/01/26/filling-curve-using-volumes-dashboard/
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
