Civil 3D Forum
changing label text
3 REPLIES 3
bhughes50
230 Views, 3 Replies
changing label text
I am trying to scale down my label text insdie of my viewport. Its about twice the size that i would like.I tried to use the scale command but nothing happens.
3 REPLIES 3
troma
in reply to: bhughes50
Set the size of label text in paperspace units in the label style.
Mark Green
Working on Civil 3D in Canada
tddbuck
Are you using annotative text?  That is controled by the scale the viewport is set to.  If it is comming in at the wrong scale to begin with you can go into the edit label style composer under the Layout tab and manually put in a text height for all the labels.  Hope this helps.
mathewkol
The scale command has no effect on the size of Civil 3D labels.  As troma stated, you'll need to edit your label style tech height option.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
