I have made 11 successful intersections in my subdivision, but there is one that just won't work!
When I get to the point where I want to set curb return parameters, the dialog box pops up but there is nothing listed under the quadrants.
If i go ahead and try to make the intersection anyway, I get this message: "one or more of the secondary road profiles cannot be locked"
Help?
Be sure that your secondary profile is editable in the drawing where you are creating the intersection. If it is a data shortcut you will need to promote it.
Thank you Jessica, but both profiles are present in my drawing, so that's not the problem...
Wel,l that it where I would have started looking. Are the vertices locked in the profiel grid view? Can you post the drawing?
I was told by Autodesk SR rep that the intersection will not work if the primary or secondary alignments have more than one layout profile in them.
Your Name
