is it possiblE to clear the page setup drop down menue in the plot dialog window? i repeatedly use the same setup that i've created and i don't like to have to go way to the bottom of the drop-down menue to select it. Also, if i clear it....how can i prevent other setups from being saved there?
thanks
yes you can, you do it through the "page setup manager, however, to make your page setup you use all the time current all you have to do is set it as current in the page setup manager.
