AutoCAD Civil 3D General
Valued Contributor
achillesgr
Message 1 of 3 (157 Views)
Accepted Solution
c3d 2014 scale setup-what is units?
157 Views, 2 Replies
11-03-2013 12:30 PM
hello,
i am new to autocad and also c3d and i am trying to figure out how the scales and printng works.
c3d the last days drives me nuts and i do not understand what is going on.
first i am working in meters .meters is choosen under the drawing settings tab .
i am trying to test print at 1:1  a rectangle with 0.2 meters side that normaly will fit in a A4 sheet since the A4 is 0.21x0.297 METERS .
in the print dialogue i set the 1"mm" = 0.001 "units".
the result is an image multiplied by 1000  .
why that? arent the " units "   METERS? METERS is what i use in the drawing so why i get a biger image?
if i set 1"mm"= 1 "unit" and NOT 0.001 i get correct 1:1 print .
what i am missing?  c3d wants me to give 1mm=1meter????
please someone help.
thanks
Valued Contributor
achillesgr
Message 2 of 3 (149 Views)
Re: c3d 2014 scale setup-what is units?
11-03-2013 01:13 PM in reply to: achillesgr
another strange thing i noticed:
if i create new drawing from acadiso template i get layouts that are in mm .i mean that the "A4 210mmx297mm" is exactly that 210mmx297mm.
BUT in my drawing the "A4 210mmx297mm" is 0
"0.21x0.297"
how one layout is in mm and the other in meters?
how can i change that?
thanks
*Expert Elite*
AllenJessup
Message 3 of 3 (132 Views)
11-03-2013 02:29 PM in reply to: achillesgr
AotoCAD and hence Civil 3D uses the actual papersize units in layouts. So in a layout the units will be in mm's or inches. The scale that the modelspace entities will plot at is an attribute of the viewport and can be set in properties.
Allen Jessup
from my nook tablet
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
