hello,
i am new to autocad and also c3d and i am trying to figure out how the scales and printng works.
c3d the last days drives me nuts and i do not understand what is going on.
first i am working in meters .meters is choosen under the drawing settings tab .
i am trying to test print at 1:1 a rectangle with 0.2 meters side that normaly will fit in a A4 sheet since the A4 is 0.21x0.297 METERS .
in the print dialogue i set the 1"mm" = 0.001 "units".
the result is an image multiplied by 1000 .
why that? arent the " units " METERS? METERS is what i use in the drawing so why i get a biger image?
if i set 1"mm"= 1 "unit" and NOT 0.001 i get correct 1:1 print .
what i am missing? c3d wants me to give 1mm=1meter????
please someone help.
thanks
Solved by AllenJessup. Go to Solution.
another strange thing i noticed:
if i create new drawing from acadiso template i get layouts that are in mm .i mean that the "A4 210mmx297mm" is exactly that 210mmx297mm.
BUT in my drawing the "A4 210mmx297mm" is 0
"0.21x0.297"
how one layout is in mm and the other in meters?
how can i change that?
thanks
AotoCAD and hence Civil 3D uses the actual papersize units in layouts. So in a layout the units will be in mm's or inches. The scale that the modelspace entities will plot at is an attribute of the viewport and can be set in properties.
Allen Jessup
from my nook tablet
Allen Jessup
CAD Manager - Designer
