hi,
when i data reference an alignment with existing and proposed profile information why doe the profile not automatically show up as the alignment does when i hit create reference?
Do you alwyas have to recreate the profile or is it not supposed to come into the new dwg in the position that it is in the original?
Thanks for yall help.
You d'refed your alignment. Do the same with the relevant profiles now as they are separate objects. They will then be available in your new file.
Be very careful with this... not saying don't do it, just be careful. I've actually started asking our users to recreate surface profiles in the final plan production sheet files, as many times a D-refed surface profile is forgotten to be updated in the Utility Model file when the Surface Model file is revised. In this case, your surface profiles will not update dynamically, nor will Civil 3D give you any warning that they are out of date. This is very dangerous, as you can send out bad data on revised drawings without even knowing. Let me explain:
Why didn't Civil 3D synchronize the surface and surface profiles when it opened Drawing D and printed? ... It did! The problem is that PG surface profile was create and lives in Drawing C, which was never opened in this process. The PG surface profile looks just like it did before the PG revision was made, since Drawing C wasn't opened and the PG surface wasn't synchronized inside of Drawing C so that Drawing C could rebuild the PG profile.
Maybe you work on small projects and do not use quite so many drawing files to create final plan sheets, but we've encountered this issue multiple times in the last year. In the past we would have checked these sorts of things, but we've grown to trust the dynamic abilities of Civil 3D so much that we move much faster and just expect things to work correctly most or all of the time. It really can be avoided by simple awareness of the data reference configuration by all the users on a project, but if you use lots of reference files like we do it is highly likely that you will run into this situation sometime... I just hope you recognize it before the drawings go out the door.
