Civil 3D Forum
automatic pipe invert update?
2 REPLIES 2
265 Views, 2 Replies
Is there a way to automatically update pipe inverts? Say you change an upstream pipe invert, how do you adjust all the downstream values? Do you have to manually edit the properties of each downstream pipe?
2 REPLIES 2
Cliff Patterson
I don't know of any other way then manually edit the inverts. Maybe someone else will chime in. If there isn't a way to raise/lower a pipe network, it should be a wish item. It would be quite useful.
Cliff Patterson
Rocke & Associates
Fort Wayne, IN.
Civil 3d 2007, SP-3
Xeon 2.80 Ghz, 2.0 GB Ram
peter_thomson
I apply rules again to all the downstream pipes and structures...
Anotherway is to simply move the downstream network in the profile..
I am hopeful that 2008 will provide a button to "keep downstream design"...in other words, move the entire downstream network up or down depending on individual changes made.
Rail Community
