Hello everyone,
Today I received mail from Autodesk containing update 1 for autocad civil 3d 2011.
After installing the updater I restart my pc. Then I launch my autocad civil 3D 2011 and start working, I find that when I using the "Pan" command or moving the crosshair, the model space start flashing.
I’m interested in receiving an explanation on how to fix this problem .
Thanks in advance ,
Ibrahim B.Dweiry Arch,
Solved by SethHall. Go to Solution.
Hi dweiry-
Please have a look at this blog post for the solution: http://beingcivil.typepad.com/my_weblog/2010/09/viewcube-and-the-white-box-after-installing-update-1...
Hope this helps!
enter command "3Dconfig"
click on "manual tune"
uncheck "enable hardware acceleration"
ok apply
issue should be resolved.
I read that you can check "enable hardware acceleration" again (which is what i did). I don't konw what hardware acceleration is, but I read on the internet that you just need to toggle it off, then back on to fix the problem.
