I am trying to generate my quantities by creating sections with template to do the cut and fill, however after i create the corridor and the corridor surface which should use the bottom of the curb, instead it is using the top of the curb. How can i change it so that it uses the bottom of the curb. It is a road crossection which i used from toolpalette, CIVIL3D 2012
Can someone help me.
Thank you
Check the overhang correction option for your corridor surface. If you switch it the Bottom setting then it will use the lowest link when there is a choice available.
