"You MAY get one to show up if your offset alignment is EXACTLY paralle to the CL alignment, but probably not."
You ever seen that happen, Matt? Back when I was ranting about offsets a few months ago, I tried doing exactly that: two single-segment alignments exactly parallel, one for baseline, one for offset. The offset subassembly did NOT show up on the sections. Just curious to know if it has EVER worked.
AD: This still NEEDS fixing.
Trevor
Message was edited by: T_Bernhard
