AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 6 (251 Views)
area in acres from line label
251 Views, 5 Replies
11-15-2012 08:48 AM
Is it possible to insert a formula or is there an existing expression I could use to calculate area in acres from a General Overall Length line label if I input the width?
Thank you
Joe-Bouza
Message 2 of 6 (246 Views)
Re: area in acres from line label
11-15-2012 09:29 AM in reply to: demus72
{General Overall Area}/43560
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Message 3 of 6 (241 Views)
11-15-2012 09:47 AM in reply to: demus72
Thanks for the reply Joe. I'm not real experienced with expressions so I'll explain what I am trying to do. I have a distance label style set up for line segments. The lines I am labeling represent the centerlines of 50 foot wide easements. What I would like the label to report is the segment length and area in acres based on the segment length. I need a formula or expression to multiply the reported segment length by 50 and then divide by 43560 and have this acreage reported in my label.
Jeff_M
Message 4 of 6 (238 Views)
11-15-2012 09:57 AM in reply to: demus72
Create a new General Line label exprssion, call it "Area of 50 foot wide easement". Use this exprssion:
In the label style, add the exprssion into the text component, formatted for Acres:
and the result:
Message 5 of 6 (230 Views)
11-15-2012 10:17 AM in reply to: Jeff_M
Eureka! Joe got me on the right track and thanks to you Jeff I was able to make it work. The part I was missing was the "Format results as" in the Edit Expression window. Now that I have it set to "Area", it works.
Now, is there any way I can make this area part of the label not print?
Thank you Joe and Jeff,
Have a good day.
Jeff_M
Message 6 of 6 (227 Views)
11-15-2012 10:24 AM in reply to: demus72
On the Format tab of the Text Component Editor, change the color for this component to be 255. Most plotters will not plot this as it is essentially white.
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
