Hi
I am trying to append a Civil 3D file created by typing NWCOUT command into Navisworks.
However when i try and do this i get the error command attached.
Has anyone come across this before and if so how did you correct.
Thanks in advance
Ian
Solved by dgorsman. Go to Solution.
The NWC exporter created a later version of NWC file than the Navisworks in use e.g. a 2014 NWC exporter was installed and now its trying to be opened with a 2013 Simulate.
Hi
Thanks for the response, is there anyway to select which version of NWC exporter i want to use or is the only way to use Navis 2014.
Thanks.
It used to prompt you for the exporter version, but that was prior to the stand-alone/non-license plug-ins. If it doesn't provide a Ribbon element to use, you might consider a few things:
