Civil 3D Forum
annotative objects scaling to current view scale
3 REPLIES 3
984 Views, 3 Replies
I love annotative scaling of objects it is a great feature. I am however having one problem that I'm not sure if I've missed a setting or something.  Is there a way to prevent civil 3d from scaling your annotative objects based on the view scale you are looking at?  For example if I zoom out (in model space or max viewport) to show my entire drawing and regen, civil 3d scales all my text and blocks to an enomous scale esentially blocking my entire drawing with solid colour. also if I zoom into a small area to do some detail work all my text becomes microscopic and unuseable. This makes adjusting text so it doesn;t overlap other text very difficult if it never appears at the correct size. Is there a way to freeze annotative objects at thier correct scale (for the current viewport scale) so they dont scale simply because you zoom in or out on a drawing?
3 REPLIES 3
david.zavislan
Once you set your viewport scale, lock the viewport.  Then all panning and zooming will occur in paperspace and will not affect the size of the Civil 3D labels.
David Zavislan, P.E. | Wood Rodgers, Inc.
The above option will help. But the text will still scale when in model space (tab) or VP Max/Min. It pretty much limits you to working in a locked viewport if you don't want to annotative behavior to drive you crazy.
david.zavislan
While on the model space tab, the text will display based on the selected annotation scale.  It will not change as you zoom in and out..  Set the annotation scale to the value that you will be using in the layout viewport.
 I don't use the VP max/min command, so I can't speak about the behavior of Civil 3D labels in that viewport mode.
Rail Community
