JGerth
Message 1 of 1 (67 Views)
alignment name changing?
67 Views, 0 Replies
09-27-2013 07:17 AM
running c3d 2011...
Yesterday, when I went home, I had two alignments in my base file, BWLK-C1, and BWLK-E-C1, proposed and existing. I had set up data shortcuts, and datareferenced them into several sheet files. All worked.
This morning, BWLK-E-C1 has a new name in the base file, BWLK-E-C1(1) - so naturally all the datareferences are broken.
I have done nothing with that alignment since it was created (after all, it's the CL of the existing boardwalk - so can't change geometry) other than change the style. WTF would cause the name to change like that.
I did try manually renaming it back, and got a message that the name was duplicated - but it does not show up in prospector in the base design file.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
